Previous in Forum: Motor HP Selection for a Screw Conveyor   Next in Forum: Air Moving Motors
Car Engine Piston Material
04/16/2007 3:43 AM
i would like to know which is the best matrial used for the piston and why?
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
Re: car engine piston material
04/16/2007 4:01 AM
What application? If it's for a mass production item, stick with an Aluminium alloy for heat conductivity, ease of casting and reduced mass. If you want a high performance item where cost is not an issue, the sky's the limit!
'The truth is out there' The lies are in your head.
Re: car engine piston matrial
04/16/2007 8:20 AM
As Plbmak said.... you could use plastic if you weren't interested in a long life piston!!!
I am assuming you are talking about a piston for use in a car i.c. engine...
Cars contain loads of different sorts of pistons, used in suspension systems, braking hydraulics, damping applications etc...
Re: Car Engine Piston Material
04/17/2007 7:23 AM
It's been a while since I was around cars but generally I.C. pistons are made of and aluminum alloy and there are probably a thousand different recipes. I know that 10 or 15 years ago makers started adding silicone to help control expansion and reduce blow-by. I could only imagine what they are doing these days.
Anonymous Poster (1); Electroman (1); PlbMak (1)
