Previous in Forum: Can Small Dot of Magnet Can be Detected ?   Next in Forum: Evaporation Rate From Waste Pits
Low Cost Styrene Control
07/05/2011 5:32 AM
Hi Guys,
We need a low budget solution to control and capture styrene, we are a small boat yard and operate in a high temp and humidity area of Asia. When we are laminating we control the environment (temp and humidity) with A/C. The resin is producing high levels of styrene, we protect the workers with adequate respiratory protection but the smell of the ventilation exhaust is really bad. What we are looking for is a solution where we can safely capture the styrene and hopefully recyle the cooled air back into the laminating shed without spending huge money on plant/equipment.
Re: Low cost styrene control
07/05/2011 5:47 AM
What is wanted is a low-volatility, low-odour solvent into which styrene dissolves readily, into which the extract streams can be bubbled. Ooooh, how about, say, a mixture of alkenes in the 20-carbon-chain region - a bit like diesel fuel, only heavier?
Kick it around, CR4!
Re: Low Cost Styrene Control
07/08/2011 1:42 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Register to Reply 2 comments
