Previous in Forum: Suggest Best VFD to Vary RPM (Max 985/Min) for a 75KW 3 Phase Motor   Next in Forum: KA Rating
Capaci of a Generator
07/05/2011 7:09 AM
Please reply asap.
1. we have a load of about 100kw, atleast how many kilowatts generator we can use there.?
2. Can we use this generator 24hrs contineously for a long time.??
Re: Capaci of a Generator
07/05/2011 7:44 AM
100kW, and yes. Is that asap enough?
07/05/2011 8:56 AM
Sir, our load is 100kw how we can use generator with the capacity of 100kw. i think it must be more than our load.
and what about the countinous running of a generator for long time ( 6 months or more) answer any experienced person please. thanks
Good Answers: 58
07/05/2011 9:08 AM
Bhatti,
Your question is too vague to come up with a viable answer.
Do some research on the internet. You should be able to find what information is required to come up with the correct size.
Try a Google search, here allow me.
Good Answers: 181
07/05/2011 9:29 AM
Two 500 KVA generators (one as stand by) should do it!
Right now to be sensible:
  • Are there any heavy loads to be started?
  • How critical are the loads
  • Power factor of the load
There's others factors I can't / don't want to think of at the moment, (I've had a few beers). You know the details of the loading we don't. If the load is critical it needs a standby generator. Heavy starting loads require a generator of X% over the base load, depending on the starting characteristics of the load. Power factor is reflected by a higher running current KVAr as to actual theoretical current KW resulting in a higher O/P required at the generator.
A 100KW generator will not supply a 100KW load.
Talk to the generator manufacturers.
07/05/2011 10:03 AM
Sir There is a load of two heavy Motors of sullary pumps 55KW each and four three phase motors of 7 KW each with 10 in nos hollogon lights of 1000 Watts.
Waiting reply please. Thanks
07/05/2011 10:17 AM
Well, (2 x 55kW) + (4 x 7kW) + 1kW is >100kW. Are the big pumps both running at the same time? If so, then the 100kW load figure is too low and a larger generator will be needed.
What about diesel-driven pumps, as an alternative?
07/05/2011 11:29 PM
You should consider LRC of motors,starting method,whether both starts together etc
pnaban
Register to Reply 7 comments
Anonymous Poster (1); Bhatti (2); KJK/USA (1); pnaban (1); PWSlack (1); TonyS (1)
