Previous in Forum: PSTB - Purpose of Phase Segregation?   Next in Forum: On Load Tap Changer
Feeder Installation
07/07/2011 4:54 AM
There is a 100 m long direct burred feeder supplying 3~ / 380 V / 300 A load . The expected voltage drop VD = ~ 1.5 % at 55 CO ambient temperature .
It could be installed as follows :
- 1 ( 4 x 700 kcmil + # 4 ) one cable run for VD = 1.24 %
- 2 ( 4 x 350 kcmil + # 2 ) two cable runs for ( VD = 1.51 % )
- 3 ( 4 x 350 kcmil + 1/O ) three cable runs for ( VD = 1.51 % )
What is the best and most economical run to use regarding material cost , labor , flexibility and reliability .
Thanks a lot for your cooperation .
Best regards
Helal basho
Pathfinder Tags: feeder designe
Re: feeder instalation
07/07/2011 5:18 AM
Cost?
Get some quotations and compare them!
Re: Feeder Installation
07/07/2011 10:35 AM
I think that is your job to find it!!! any way it is you and you only that can better access the place were the installation is to be built!
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Good Answers: 181
07/07/2011 7:10 PM
What installation? It's only in the mind of the course tutor.
Go away and do your own homework!
Register to Reply 3 comments
electronick (1); PWSlack (1); TonyS (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
