Previous in Forum: Need Help on the Use of Banana Trunk as Source of Ethyl Alcohol   Next in Forum: Fuel to Oil Ratio
Leakage in Wall
07/07/2011 3:39 PM
Hello Everyone
How to find out the wall leakage is low or high.
cause approx. 2.5 feet from flooring the paint is gone. some part of the wall the white cement can be seen and on other the plaster can be seen. whats the best solution for the same.
The bathroom is near.
thanks
Re: Leakage in wall
07/08/2011 3:48 AM
It sounds as though part of the plumbing in the building has a leak containment problem. Fix it.
Reply to Forum Thread
