Previous in Forum: Leakage in Wall   Next in Forum: Furnace
11 comments
Fuel to Oil Ratio
07/07/2011 11:51 PM
I need a little help detemining the amount of oil I need for lawn equipment with a 50/1 fuel/oil ratio . Every 2 clcle that I own has a fuel to oil ratio of 50/1. My 4 oz. bottles of oil only shows a mixute of 32/1. That will mix 1 gallon of gas@ 32/1. I need to know how much oil should I mix with 2 gallons of gas at a 50/1 ratio?
Re: fuel to oil ratio
07/08/2011 12:19 AM
That's too complicated for me.
50/1, 32/1; sooner or later it works out to whatever the ratio is for 2 gallons.
Would that be 50/2? or 100/1?
07/08/2011 12:34 AM
the can only shows the fomula for a 32/1 engine, but i need a fomula for 50/1 using the same oil. i bought a case of it, so i'ld like to use it in my new equipment
07/08/2011 12:34 AM
2 gallons ÷ 50 = 1/25 gallon = 16/25 cup, which is just shy of 2/3 cup. You can just eyeball this, because it doesn't need to be especially precise.
07/08/2011 7:12 AM
GA..................just to add, I usually eyeball it slightly over. I'd rather deal with a little smoke than burnt rings.
07/08/2011 7:46 PM
it's my understanding that synthetic won't burn so it won't smoke either. just thought i'ld throw that in.
07/08/2011 8:15 AM
Exactly.
Another way to say or measure it: 256 (ounces in two gallon)/50= 5-1/8 ounces of oil per two gallon of gasoline. I subscribe with your method... does not need to be exact, and a little too much oil is better that a little bit not enough.
Good Answers: 141
07/08/2011 1:23 PM
How many table spoons is this? Or tea spoons? LOL Are these imperial gallons? US gallons? Why is metric that simple?
Plenty of room here
07/08/2011 1:37 PM
You know, that is a very good point!
Please disregard my #5. I was talkin' when I shoulda been listnin'. Our OP never said US gallon... So, I have no idea how much oil to mix with a gallon.
Re: Fuel to Oil Ratio
07/08/2011 9:16 AM
Wow. A simple ratio calculation of 50:1 is too much mathematics for the common person. This bothers me. I know our education system has been declining but .... Certainly our antiquated measuring system of gallons and ounces makes this a little more complicated of a problem. But this is not like finding the eigen vectors of a 5X5 diagonalized matrix.
07/08/2011 7:40 PM
thanks for your help. appreciate it.
02/21/2025 6:00 AM
Hint: 50/32 = 1.5625.
Register to Reply 11 comments
Doorman (2); dvmdsc (1); jlstitt (3); kramarat (1); lyn (1); PWSlack (1); redfred (1); Tornado (1)
You might be interested in: Oil Sensors and Oil Analyzers, Fuel Cells, Fuel Testers
