Previous in Forum: Coefficient of Friction for Contact Between Stainless Steel & Teflon   Next in Forum: Dosing Pumps
Surge Pressure
07/11/2011 3:18 AM
What does Surge pressure means ???
and how I can protect pipes from it ?
Re: Surge pressure
07/11/2011 4:03 AM
Surge happens when fluid in motion is stopped by a valve or other obstruction shutting it off and needs somewhere to go to slow down. The simple way of containing it is with some form of hydraulic accumulator.
Pipes need to be rated for the surge pressure to be satisfactorily protected.
Re: Surge pressure
07/11/2011 4:10 AM
thank you for your help
Good Answers: 67
Re: Surge Pressure
07/13/2011 5:30 AM
Surging is nothing but frequent reversal of flow in short time. In centrifugal compressors it happens when consumption of compressed gas in downstream is suddenly reduced or stopped. In steam piping it happens due to excessive condensate formation or condensate is also to be pushed through along with steam. In both the cases resultant is very heavy jerk and vibration in piping. Some times flanges and valve glands may get loosened and start leaking.
The best protection is to avoid surge by (a) provision of anti surge controls in compressors (b) provision of adequate auto condensate drains in steam piping and its maintenance.
To take care still eventual surging, piping support and clamping should be strong.
Re: Surge Pressure
07/13/2011 6:05 AM
really thank you
Good Answers: 11
Re: Surge Pressure
08/08/2011 9:16 AM
GA. OP's case fits into which of the above 2 situations?
When there is smoke, there must be fire.
prdp2344 (1); pritam (1); PWSlack (1); stylee_eng (2)
