Previous in Forum: Surge Pressure   Next in Forum: Tolerance for Static Blade Angle of Axial Turbo Blower
9 comments
Dosing Pumps
07/11/2011 4:16 AM
what does it for ???
and its applications ?
Re: Dosing Pumps
07/11/2011 4:35 AM
this type of question is similar to other questions i found here in CR4. the same answer is: CR4 IS NOT A CHEAT SITE FOR HOMEWORKS, DO YOUR OWN RESEARCH.. READ CR4 TERMS AND CONDITIONS BEFORE POSTING!
what do ou think "dosing" means?
Re: Dosing Pumps
07/11/2011 4:43 AM
i ask about the practice field ,, really i do not know it
Re: Dosing Pumps
07/11/2011 4:54 AM
try googling your question..
anyways, as answered in #3, dosing pumps is used in water treatment, putting a controlled amount of chemicals in order to have a desired water characteristics/properties.
Re: Dosing Pumps
07/11/2011 4:47 AM
Dosing is used extensively in water treatment, to meter small proportions of chemical into a larger flow.
Re: Dosing Pumps
07/11/2011 4:53 AM
thank you ...
is there a special design to it ?
Re: Dosing Pumps
07/11/2011 5:07 AM
Always.
Re: Dosing Pumps
07/11/2011 5:38 AM
Dosing pumps are used for many applications. At the small end there are peristaltic pumps dosing detergent and rinse aid into commercial dishwashers.
They are also used in laundrys to dose detergent, destainer, starch, softener and suchlike.
Water treatment, as said before is a major use, with swiming pools being a small scale application in this field.
Re: Dosing Pumps
07/12/2011 2:33 AM
thank you for your support
Register to Reply 9 comments
lito (2); lyn (1); PWSlack (2); stylee_eng (3); user-deleted-1105 (1)
