Previous in Forum: Unit Conversion   Next in Forum: Vibration
PMA Motor of 12Volt,5Amp
07/13/2011 3:17 AM
I have a small PMA motor of 12Volt,5Amp
I want to charge the 12 Volt,150Amp Batteries
Which component can I use to get 12 Volt,60Amp out-put to charge my batterie?
Thank you for the reply
Re: New Technologie & Research
07/13/2011 3:51 AM
Just put a blocking rectifier between the motor and the battery, so that the current only flows from the motor to the battery. Once the correct polarity has been established, spinning the motor in the correct direction, assuming it is a permanent magnet motor of course, will charge the battery.
And this is hardly "new technology", though it might be called "research" on a personal level.
Re: PMA Motor of 12Volt,5Amp
07/13/2011 8:43 AM
Gustave; connect the motor to the A.C. terminals of a full wave rectifier, connect the
plus of the rectifier to the plus of the batteries, i don't know where you would get the 60 amps! perry
07/13/2011 11:49 AM
This:
S.M.
Register to Reply 3 comments
Anonymous Poster (1); perry (1); PWSlack (1)
