Previous in Forum: Power Piping (Velocity?)   Next in Forum: PMA Motor of 12Volt,5Amp
Unit Conversion
07/13/2011 2:54 AM
can anybody help me to change unit from Nm3/hr to m3/hr
Good Answers: 18
Re: unit conversion
07/13/2011 3:16 AM
Hi krishnirtt,
Nm³/hr (Normal meters cubed per hour) and m³/hr (meters cubed per hour) are terms for compressor output or machine consumption of compressed air and are the same. The Nm3/hr is the correct terminology as the output from a compressor is quoted at atmospheric pressure and not when it's compressed.
Best regards,
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
Good Answers: 67
Re: unit conversion
07/13/2011 4:28 AM
Not only pressure, temperature correction is also required for conversion.
Nm³/hr (Normal meters cubed per hour) is volume rate of flow at normal temperature (0 deg C) and one atmospheric pressure. It is more accepted definition. Some places normal temperature is taken as 20 deg C.
Good Answers: 137
Re: unit conversion
07/13/2011 5:09 AM
Assuming by m3/h you mean (gas) flow at actual conditions, formula is
m3/h = Nm3/h/P*(T + 273)/273 where P = pressure in atmospheres (absolute), T = temperature in °C. 1 atmosphere = 760mm Hg = 1.01325bar.
Codey
Register to Reply 3 comments
Codemaster (1); jesw55 (1); pritam (1)
