Previous in Forum: How to Figure Gearing, Motor Size (hp and Torque)   Next in Forum: Unit Conversion
Power Piping (Velocity?)
07/13/2011 12:26 AM
Hi,
Please let me know that the required design velocity for the following pipe lines for Combined Cycle Power Plant?
- HP Steam Line
- MP Steam Line
- LP Steam Line
- Turbine Bypass Line
- HP/LP Bypass Line
- Boiler Feedwater Line (BFP Suction & Discharge)
- Condensate Water Line
Pathfinder Tags: Power piping velocity
Good Answers: 53
Re: Power Piping (Velocity?)
07/13/2011 12:45 AM
Greater than zero. Less than mach 1.
07/13/2011 3:57 AM
Economic considerations of pressure drop versus pipe size would suggest that, as a rule of thumb, if a gas flow exceeds 10m/s then the piping is too small. For a liquid, the figure is around 3m/s.
Good Answers: 67
07/13/2011 4:48 AM
I can suggest following:
- HP Steam Line- (PN64) : 45 m/s
- MP Steam Line- (PN25) : 35 m/s
- LP Steam Line- (PN25) : 30 m/s
- Boiler Feedwater Line - 3 m/s
Good Answers: 38
07/13/2011 10:29 AM
JBK....
Recommended velocities for the systems you mentioned are contained in the Piping Handbook, by Nayaar.
Please be aware that, in real Engineering Companies (like, say Bechtel), a detailed study is done comparing Main Steam, HRH & CRH piping diameters vs. best steam velocities in order to get the best financial ROR over the plant life.
These systems are so important and can affect the overall plant economics, that a detailed study is warrented.
Is this the first time that you have ever sized piping systems ?
-MJC
Register to Reply 4 comments
Ace Boeringa (1); MJCronin (1); pritam (1); PWSlack (1)
