Previous in Forum: 4000PSI Pipe Spec for Pressure Washer Question   Next in Forum: Power Piping (Velocity?)
How to Figure Gearing, Motor Size (hp and Torque)
07/12/2011 10:20 PM
I am building a motorcycle lift.... I want to be able to lift 1800 pounds... I am interested in a winch setup... I need 115 volt motor... I am not picky about what I need and am open to suggestions...
Re: how to figure gearing, motor size(hp and torque)
07/13/2011 12:23 AM
I would consider a 1000-pound 12-volt boat or RV winch, a small car battery, and a charger; with the cable end anchored high and passing under a pulley with a hook, and then back up to the winch.
07/13/2011 3:58 AM
The power of the motor must exceed the rate of increase of potential energy of the load by a factor that is at least the reciprocal of the system mechanical efficiency.
Re: How to Figure Gearing, Motor Size (hp and Torque)
07/13/2011 11:37 PM
To the regulars, I don't work for McMaster Carr, but they are handy
http://www.mcmaster.com/#winches/=d605d3
They even have some diagrams.
Working to end the use of carbon for energy
07/14/2011 4:35 PM
If you do decide to use a winch, keep in mind that most winch manufacturers weight rating is at 50% of the cable length. in other words if the spool holds 10 wraps the weight rating is calculated at the 5th wrap. Ideally you would determine exact;y how much cable you need then leave 3 wraps on the spool and remove the remainder. I would not recomend double roping as this reduces the life of the cable by going around a pulley. Hope this helps
repeat problems can not be solved by the same way of thinking ( A. Einstein)
07/19/2011 12:02 PM
i was hoping to make one i have a 1/2 horse electric motor 110volt... and would like to figure gearing.. i am a machinist but i have never needed to configure something like this...
07/24/2011 6:06 PM
Register to Reply 6 comments
baker87 (1); dthomas16 (1); PWSlack (1); regsoft (2); Tornado (1)
You might be interested in: Lift Tables, Lift Stations, Tie Down Straps
