Previous in Forum: Short Circuit Calculation   Next in Forum: Sag Selection From Sag-Tension Table
12 comments
project report based on motor control center
07/19/2011 10:22 AM
why motor being trip due to overheating?
Re: project report based on motor control center
07/19/2011 10:34 AM
Over loaded, or under powered.
07/19/2011 10:42 AM
The most common reason I've found is operator error.
07/19/2011 10:43 AM
The answer is in the question.
India - Member - New Member
Good Answers: 164
07/19/2011 11:04 AM
The motor doesn't trip. If run long enough, it may burn. It is the protective relay which trips, and cuts off power to the contactor which supplies the motor.
As to why it should trip, that is its raison d'être
07/19/2011 11:17 AM
I've seen electric motors with built in thermal switches that require a manual reset (push button) when tripped. So the motor itself maybe tripping. Then again maybe you're correct and an external relay is tripping. Then again with the sparse amount of information from the OP, this could even be a virtual motor being used in a simulator. Where the OP has virtually wired 220VAC to a GUI motor icon that defaults to a 24V DC servo operation. This would quickly generate a project report error for this poor little overdriven virtual motor.
Good Answers: 164
07/19/2011 11:34 AM
Oh yes, thanks for reminding me about that one ... Klixon was one such? Not seen in India though.
This is about as close as we will get to 'how flashlight work?' i suppose. i did see one about how to connect a lamp, but the lamp did look complicated and maybe that question was justified .....
Good Answers: 804
07/19/2011 12:37 PM
◊ "As to why it should trip, that is its raison d'être" ◊
Love that answer!
Good Answers: 164
07/19/2011 8:40 PM
In retrospect, rather nasty, i realise, given the OP's 'wot dat' level...
07/19/2011 8:57 PM
Elitist!
Good Answers: 164
07/19/2011 10:50 PM
You bet !
07/19/2011 11:13 PM
Have two or three for me.
Cheers!
07/20/2011 12:20 AM
You must check current,load applied,bearings,ventilation,IR etc
pnaban
Register to Reply 12 comments
JRaef (1); kvsridhar (4); lyn (3); pnaban (1); PWSlack (1); redfred (2)
