Previous in Forum: Frequency Test With Time Delay   Next in Forum: Protection for Ungrounded System
Substation Transformer Voltage Sag
07/19/2011 6:41 PM
Hi,
during a tap change for few mseconds there is a voltage sag in the system. the voltage goes down from 115V to 98V for 8 mileseconds.
we have tested for the winding resistance test using MTO-210 for testing "make befroe break" and this test doesn't show any problem. The SFRA also doesn't show any obvious problem. we tested for excitation, PF, TTR,... no obvious signs. One of the engineers suggestion was that it might be the LTC lead loose/bad connection in the tank, but the test couldn't confirm this.
Is there anyone might have some idea to findout the source of this problem.
Re: Substation Transformer Voltage Sag
07/19/2011 8:33 PM
Well 8 milliseconds is almost exactly one half cycle of a 60 Hz signal. Unless you really did mean 8 mile seconds? Then with the electricity traveling at a nominal 65% of the speed of light in a vacuum that puts it at about 121,000 miles/second.... Nah that's not making sense. You must mean that you see a power dip for one half of a power cycle. Frankly, I can think of some power distribution arrangements that this would be normal. I can also think of ones that this would be a sign of instability. It all depends on your configuration and your method of testing. Sorry but I don't have enough information to go on.
Or maybe I've just confused myself again.
07/20/2011 9:28 AM
Hi redfred,
not mile seconds, but it is milliseconds. Thanks for the correction. However the exact sister unit feeding the same load doesn't exhibit the voltage sag problem during the tap change transition.
any thought?
Good Answers: 11
07/20/2011 12:21 AM
Isn't this dip normal for this type tap changer.
Talk to tap changer manufacture.
Good Answers: 131
07/20/2011 4:00 PM
I agree with Carl Pugh, check with the LTC manufacturer.
However, it could be a problem with the contacts of the tap changer. How old is it? How many operations does it show on the op counter? If the contacts are very burned, there could be arcing taking place, or poor contact making/breaking. This could cause voltage excursions. Maybe a tap changer internal inspection and service is required. Contact a reputable, experienced HV testing & maintenance company for help.
Good Answers: 59
07/20/2011 11:42 PM
Mechanical contacts rarely move in the single Millisec range. 10 msec or above is good. Now, improvements are made with make before break arrangement.
BUT, wherever real power is in play, contacts normally come in pairs. One makes and breaks, suffers from arcing. And for all this abuse, its contact characteristics are not great. The other of the pair is not abused. It only makes contact after the first, to make a low Ohm safe connection.
IF, you cannot measure precise enough to distinguish, and your abused first contact is flaky or already failed, you described your situation quite correctly.
Good Answers: 27
07/21/2011 10:49 AM
The slight power sag or delay may have been caused by a contact bounce or some sort of dirt caught in between the contact points?
vsar
Anonymous Poster #2
07/26/2011 5:37 PM
Hi there
Check the Tapchanger contacts...maybe they are burnt
Cheers
Anonymous Poster (2); Carl Pugh (1); leveles (1); PeterT (1); redfred (1); vsar (1)
