Previous in Forum: Steel in RCC   Next in Forum: Truss Type RR Bridge
LRFD AND ASD calculations(URgent)
07/19/2011 7:45 PM
hey
i am doin lrfd and asd calculation to determine base seizes, however am using metric unit and am getting weird answers. i know with imperial you used kips, inches etc , what units should i use (metric) to get proper solutions? Or is there a diiferent formular for metric units?
Engineering Fields - Transportation Engineering - New Member
Re: LRFD AND ASD calculations(URgent)
07/20/2011 1:56 AM
....revise back to units conversions,if formulas needs imperial measures inputs then convert what you have and work it out......
.............kaa nami!
07/20/2011 7:37 AM
Before using metric units, please perform an acronymectomy procedure.
07/21/2011 1:35 AM
It's URgent! So who has time to explain acronyms/abbreviations? (Though doing so would help people to respond more quickly....)
07/23/2011 3:11 AM
Hi there, your calculation results (Wierd) seems to be stemming from improper unit conversions and or improper dimentioning of the units. I recommend that you use MathCad. Basically the formulae are same there cant be a different formula for a different unit system (FPS, CGS, or MKS). Take care that you may be using a force unit as pressure. When using MathCad please use force units as Eg. kgf for kilogram force else you will have Wierd results. Hope that helps.
Byansheko (1); Mohammed Fareeduddin (1); PWSlack (1); Tornado (1)
