Previous in Forum: Non-Combustible Insulation   Next in Forum: PCB Enviromental Protection
h2so4 Storage Tank
07/20/2011 5:55 AM
what is the purpose of acid box placed above sulphuric acid storage tank? vent pipe is connected to box & sulphuric acid inlets are taken in box & outlets are given to tank.
Be not afraid of growing slowly, Be afraid only of standing still.
Re: h2so4 storage tank
07/20/2011 6:14 AM
Are there any other fluids connected to this box?
Of what material are the box and the tank made?
07/20/2011 6:42 AM
What concentration is the acid?
07/20/2011 12:01 PM
acid conc. is 98 wt% & inlet is from acid plant . moc is ms rubber lined
Good Answers: 61
Re: h2so4 Storage Tank
07/20/2011 12:04 PM
Concentrated sulphuric acid (if that is what it is) has a very strong affinity for water and will extract water vapour from the atmosphere, diluting itself in the process. It is also highly corrosive of course. Could your box and pipework be a system to prevent water vapour from entering the storage tank? Or could it be a system to prevent the escape of corrosive vapour from the tank? Or both?
07/20/2011 12:28 PM
Then there should not be overflow line to storage tank as it will absorb water vapor from atmosphere that means tank overflow will go to top vent line to acid box. Does providing overflow causes acid dilution?
sir, does providing acid box reduces fumes of acid that is splashing of acid?
i have read through acid handbook that dilute acid is more corrosive than conc. so acid box to prevent water absorbtion from atm. is seems convincing.
Good Answers: 61
07/20/2011 2:02 PM
It is true that concentrated sulphuric acid is less corrosive than diluted, because it is essentially a covalent compound. Only in the presence of water will it ionize to H+ ions and attack metals and organic matter. Normal concentrated sulphuric acid is 98% pure, but "oleum" is c. H2SO4 in which sulphur trioxide has been dissolved. The SO3 reacts with H2O to form more H2SO4, so keeps the acid at 100% strength. I don't know if this is relevant to your situation.
Register to Reply 6 comments
bhalchandra (2); energyconversion (2); PWSlack (2)
