Previous in Forum: Heat Generation by Given Size of Parabolic Dish   Next in Forum: Multimeters
Need P&I Diagram Symbols & Basic Information to Draw
07/20/2011 8:22 AM
Dear...,
I m searching for P&I Diagram symbols. I want to make one P&I Diagram for Motor. Pls reply me with some links where i wil get related symbols of P&I. I searched in Google but i didn't get satisfied result.
Pls do the needful.
Thanks & Regards
Mahesh
Re: Need P&I Diagram Symbols & Basic Information to Draw
07/20/2011 8:50 AM
There is no symbol for a motor on its own, as a motor doesn't do anything on its own. It turns something else. What is it turning?
07/21/2011 12:14 AM
Sir,
There is a motor which is used to rorate blower. I need to make P&I diagram to show Motor main winding temp., Hot & Cold air, Bearing temp., Excitor temp, Rotor signals, vibration monitoring, lub oil & jack oil system and water flow and pressure & temp etc. so pls provide the link or data regarding this.
Thanks in advance.
Mahesh
07/21/2011 5:51 AM
Then contact the Process Engineer on the job.
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
07/25/2011 5:47 AM
Mahesh,
Try using Matlab Simulink, you will get related things.
you need to go, to get something
Register to Reply 4 comments
maheshps (1); PWSlack (2); sharath4 (1)
