Previous in Forum: Mild Steel Ladder for the Blast Resistant Structure   Next in Forum: Fully Burned Brick
HFO Tank Design
07/20/2011 9:53 AM
Dear All,
I need the design procedures and the Code details to be followed for HFO ( Heavy furnace Oil) storage tank design.
thanks in advance.
N.Vigneshkumar
Pathfinder Tags: HFO tank Design Procedure
Re: HFO tank design
07/20/2011 10:00 AM
Size?
Re: HFO tank design
07/20/2011 11:18 AM
The inner dia of steel tank is 9m and 20m height
N.Vigneshkumar
Re: HFO tank design
07/20/2011 11:39 AM
Does it sit on the ground, or does it have legs?
Re: HFO tank design
07/20/2011 1:15 PM
The steel tank design already done. The supporting foundation for the tank suppose to be design as RCC ring beam with raft foundation. For that i need the procedure and relevant Code books.
N.Vigneshkumar
Good Answers: 101
Re: HFO tank design
07/20/2011 2:11 PM
You will need to buy the codes, everyone else who needs them has/does. It is Illegal for someone to "give" you a copy of the codes. They are not cheap, but if you need them, you will need to pay for them.
Re: HFO tank design
07/20/2011 3:06 PM
I knew that sir. But my requirement is only that the procedure for design and the reference code book list, that means the guide line details. Thats it.
N.Vigneshkumar
Re: HFO Tank Design
07/20/2011 11:42 PM
The code used in design of welded tanks for oil storage is API 650.
Register to Reply 7 comments
Abdel Halim Galala (1); jai.vignesh (3); PWSlack (2); RVZ717 (1)
