I will see if any info exists for the size you want.. However there is a lot more information required.. Pressure? fluid? Gas? what material are you mating to and do you intend to use a gasket and what type did you have in mind .. flat or recessed ring.. not as simple as just drawing one.. I could do that no problem but the calcs are important and the info necessary before i would try ..
