Previous in Forum: Drawings for Flanges   Next in Forum: Deration Factor
9 comments
Turbine Efficiency
07/21/2011 12:55 AM
For an LPG processing plant design, it includes an LPG Turbine generating power. What is a good efficiency number to use in a HYSYS steady state process simulator? Is 67% to 75% a good number?
Pathfinder Tags: turbine
Good Answers: 137
Re: Turbine Efficiency
07/21/2011 11:43 AM
I don't know what "a HYSYS steady state process simulator" is, but if by efficiency you mean shaft power out divided by heat input from burning the LPG, your figures are much too high. I would expect something more like 25% to 35%, depending on size of turbine (bigger tend to be more efficient) and nature of load (steady, fluctuating etc)
Codey
Good Answers: 125
07/21/2011 2:17 PM
Yes, I have heard of breaking the 50% efficiency line with the newest units but they were in the 200+ megawatt range.
Good Answers: 49
07/21/2011 11:32 PM
AND they were combined cycle- using waste heat to make steam to drive a turbine parallel to gas turbine. Also- 50% is OK if you can make some very high steam pressures OR use DUAL steam turbines with high and medium pressure inputs.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
07/21/2011 11:38 PM
Very grateful for your response. With all the replies I have had, it seems turbine efficiency is always on the low side.
07/21/2011 11:36 PM
Thanks for the reply. Appreciate it. seems efficiency is low for turbines compared to compressors.
Good Answers: 137
07/22/2011 6:56 AM
That's right, because unlike compressors turbines convert heat into mechanical power. Due to the 2nd law of thermodynamics, even the theoretical maximum efficiency is well below 100%.
07/22/2011 7:10 AM
thanks
07/22/2011 7:29 AM
Check out the Power Generators made by Capstand Corporation.
07/22/2011 9:02 AM
For HYSIS simulations, you need to use the factor given by the manufacturer or the turbine, do not use arbitrary percentages, since they will give an inherent calculation errors.
Most turbine manufacturers will give you their factors if you are serious about buying their equipment.
Register to Reply 9 comments
Codemaster (2); dadw5boys (1); energygod (1); jamil ghani (3); vargaalex (1); WJMFIRE (1)
