Previous in Forum: Civil Engineers in Oil Companies   Next in Forum: I Want To Learn And Work With Structural Designing Firm Or Company
14 comments
Good Answers: 25
Pre-Engineered Steel Buildings
07/22/2011 8:25 AM
One of my clients is planning to put up Mini Steel Plant for casting Steel Ingots. He has received offers form local steel fabricators and Pre Engineered Steel Building (PEB) mfrs. for fabrication of the shed. PEB offer is cheaper and lighter in weight. More over environment is hot, corrosive and dusty due to melting of steel in Electric Arc Furnace. This may affect life of such buildings.
Any of our friends in this Forum have experience of PEB buildings for Steel Plant? Please let me have your expert comments.
Good Answers: 114
Re: Pre Engineered Steel Buildings
07/22/2011 9:52 AM
Much depends on how the building is use, will it have a highly used bridge crane? operators will often slam them into the buffers to true them up when they "crab", will it have production forklifts running around at high speed? operators get careless in their haste to make production goals.
I would elect to use the fabricated building, it is much more able to withstand mistreatment because it has reserve capacity. The fabricated building uses standard shapes that are rarely an exact fit, so they have spare capacity. The PEB uses custom material that just meets minimum requirements.
Generally, PEBs are useful when they just provide a protective envelope but not when they are part of the process.
Good Answers: 25
07/23/2011 2:49 AM
There will be three EOT Cranes running in the shed, 1 No. 50 Tonne Laddle pouring crane, 2 Nos. 20 Tonne billet handling cranes. There will not be any fork lifts in the shed.Of course there will be rough and tough conditions in the plant.
09/04/2011 2:06 AM
Excel Engineering Company-Bangalore, Manufacturer and Service Provider for Pre-Engineered Building Systems, Offers Flexibility in Design, Fabrication and to Erect Steel Structures to Suit Construction Needs at Home, Office, Factory etc.,
The Distinct Advantages of Our Products:
Cost Effective
No On Site Welding
Low Maintenance
Ease Of Erection
One Time Investment
Light weight Structures
After Sales Service
Quality Assured
Tailor Made Steel Structures
Product Range:
Pre-Engineered Steel Building/ Structure (Column, Beams, Rafter Sections, Purling)
Pre-Engineered Building Accessories (Steel Door, Automated Doors, Shutters, Automated Shutters )
Mezzanine Floor System( Modular , Fixed type of Mezzanine Floor)
Pre-Fabricated Buildings (Cabin, Office, Rooms, Out House, Garage)
Industrial Enclosures( Barricade, Safe guard Enclosures, Free Standing Partitions)
Services:
Erection Services of Steel Buildings and Structures
Metal Sheet Roofing and Cladding Services
Building Maintenance Contract
Site Supervision Contract
Bangalore
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Web: www.excelengineering.webs.com
Good Answers: 204
07/25/2011 10:23 AM
excellent! ga
Good Answers: 179
Re: Pre-Engineered Steel Buildings
07/22/2011 2:17 PM
There's a lot of "what ifs" and other conditions that affect the ultimate design of a traditional steel framed building versus a PEB, and what is finally acceptable to you the owner or operator, including management.
I'll go with passingtongreen on his assessment......PEB's offer better economy as well as specific engineering design customized to the specific uses and manufacturing processes. Most well experienced PEB fabricators that are larger in nature and have been a long time have professional structural engineers on their staff that can design proper steel frames to accept overhead crane rail loads and other needs, all tailored to your shopping list. You can get this also with traditionally design steel or reinforced concrete structures, but the end result will be a higher cost, a delay of construction, and a longer construction period.
Although I haven't been involved in the design of a new foundry buildings that featured overhead crane systems I have been involved in the design of other heavy industry and manufacturing facilities. Closest that I have come to deigning a building for a steel foundry has been a retrofit of certain heavy manufacturing buildings at the Watervliet Arsenal (Watervliet, NY), whose operations are overseen by the US Army's Material Command. But then the steel frame was a traditional one, not a PEB type. [The Arsenal currently manufactures 120mm smooth barrel tank cannons used in the Army's M1A1 Abrams Main Battle Tank, as well as 105mm artillery tubes. It is the oldest continuously operated military arsenal in the US (since 1812 I believe, but don't quote me on that).]. I've designed other heavy massive lift overhead crane systems (w/ retrofits and upgrades) for GE Steam Turbine Assembly Building and at a couple of buildings within KAPL, both located in Schenectady NY and it's suburb Niskayuna respectively.
ps: Anyhow, sometimes it's advantageous to have a "stand-alone" overhead crane system, purely based on the need for flexibility, maintenance and economy.
07/23/2011 12:35 AM
I think I would coat the steel with a Coal Tar Paint is resist almost all attacks and will make the steel of the building last a long time.
The only bad thing about the coating I have ever seen is it will get very brittle and chip if hit a lot .
Of the owner can keep things from hitting the walls he will get a long life out of the material, in my opinion
07/23/2011 7:32 AM
I can offer the Best deal.Let us know what is needed.
Good Answers: 25
07/24/2011 6:12 AM
If you are from India then it is ok otherwise shipment of 800 Tonnes of steel is biggest problem.
07/24/2011 8:35 AM
I am from India
800 Mt can be cut down to half or even less through Rationalized Design and fabrication.
And why carry ?
You have all the Steel and all the fabricators at Mumbai.
Try me.
Good Answers: 179
07/23/2011 11:30 AM
I don't think a coal tar coating would hold up well in a extremely hot environment such as a steel foundry. There is a very high potential for the coating to ignite, as the furnaces reach several thousands of degrees (F) temperature...then there is radiated heat to deal with. You need an ample amount of air space between the furnace, hoppers and rolling beds and the steel structure.
A better coating such as hot-dipped zinc galvanizing or hot-temperature resistant epoxy paint would last a much longer time period.
07/24/2011 5:38 AM
we've had very good luck with hot dipped zinc sheeting, as captmoose has suggested, in these situations. heat shields should prevent the sheets from warping if thats a problem i'ld stay away from buying a pre-fab. they try to sell buildings that they've already designed for general useage.
Good Answers: 25
07/24/2011 6:17 AM
It is question not about only surface finish of the structures it is suitability of such buildings for industrial purpose. Its stability, load taking factors, corrosion resistance from furnace fumes and heat.So far PEB mfrs do not have track record in this sector but they are confident their building can meet all requirements.
07/24/2011 10:33 AM
yes i realize that, but it was just one example as to why a pre-fab would not be a good chose. your customer will need a speially designed building to suit his needs. i've erected dozens of pre-fabs, and i assure you that you will end up with what we call in the trade as a "tin building" that is'nt suitable for anything industrial.
Good Answers: 25
07/24/2011 12:27 PM
Thanks for your reply.I will convey my customer accordingly.
Register to Reply 14 comments
CaptMoosie (2); chrisg288 (1); dadw5boys (1); Excel Engineering (1); jlstitt (2); MUKULMAHANT (2); passingtongreen (1); suresh sharma (4)
