Previous in Forum: Drum Brake Adjustment AMHOIST AM77EF Winch   Next in Forum: 2001 Sebring Gauge Lights
Gas Used In Gas Struts
07/24/2011 9:32 AM
I believe Nitrogen is used in gas struts. I also note that when it's cold, my car boot only just stays open. But in summer it flies open and almost takes my head off.
I'm aware that p1V1/T1 = p2V2/T2, but because T starts at -273°C and p at -98kPa Gauge then the small change in Temperature makes very little difference to the Volume or pressure.
Is there something special about Nightrogen?
Tony
The nice thing about Standards is there are so many to choose from.
Pathfinder Tags: expansion gas gas strut
Re: Gas used in gas struts
07/24/2011 9:44 AM
You could always employ a "helper" scooter in the cooler months.
07/24/2011 9:54 AM
As far as I can tell from the table here, the viscosity of air (mostly nitrogen) varies from about 13.3 to 17 m2s-1 over the temperature range 0 to 40°C, which is quite a big percentage change, so the properties of the strut (depending on the rate the gas passes through the orifice) can be expected to change quite a lot over the range. This, combined with the pressure change, probably explains it.
Just my thoughts.
Re: Gas Used In Gas Struts
07/24/2011 11:13 AM
i doubt if they're nitrogen filled. perhaps fluid filled like a sreen door closer. but it's most likely the grease the use to lubricate it.
07/24/2011 11:21 AM
Where have you been? Why do you think they are called gas struts? I don't think you'll find any liquid in a screen door closer. It's mostly a spring and a vent valve.
And, gasses are fluids.
HOME | ABOUT | GAS SPRING STRUTS? | APPLICATIONS | CONTACT | PRODUCTS | REPLACEMENTS | NEW APPLICATIONS
SOURCE: www.msengineering.co.uk
The oil is for lubrication. No springs here.
07/24/2011 9:17 PM
hey lyn, keep in mind #3 post is the same person wanting to run 20amps thru 14ga wire. so please be east on them, who ever they are.
Good Answers: 70
07/24/2011 2:31 PM
Buy only gas struts that are manufactured during the winter months, that way you won't have to depend on some low payed yahoo to make the proper temperature corrections during the summer months. DJ
07/25/2011 3:50 AM
Generally, if a strut is sized correctly, it will work fine winter and summer for a few years, but eventually minor losses of gas cause it to work badly in the winter.
If your strut was in fact over sized for the job, and its also over two years old, I can imagine that it would give EXACTLY the problem you describe.....replace it/them.
Do remember that the thick part must be at the top, or you will be replacing them even more often....
Register to Reply 7 comments
Andy Germany (1); Anonymous Poster (1); dj95401 (1); jlstitt (1); JohnDG (1); lyn (2)
