Previous in Forum: Radiator   Next in Forum: Temperature Range for LTCS
Engine Deration Calculation in Cummins Engine in DG Set
07/26/2011 6:37 AM
Sir,
  1. Can u please tell me the engine deration calculation for cummins engine in a DG set, the engine is Turbo charged Intercooled?.
  2. I know the engine performance is affected by site altitude, temperature and humidity, but I don't know how the humidity affects the engine performance, can u please clear my doubts.
Thank you.
Re: Engine deration calculation in Cummins Engine in DG set
07/26/2011 7:10 AM
In case of extreme humid conditions, more water vapours are present in air. So in a given volume of air, less oxygen is present.Hence combustion process would be affected, hence the deration
Re: Engine Deration Calculation in Cummins Engine in DG set
07/26/2011 8:00 AM
It's also affected by altitude, as this is a function of air pressure. Isn't it in the User manual?
Good Answers: 120
Re: Engine Deration Calculation in Cummins Engine in DG Set
07/27/2011 4:42 AM
seek and you shall find the plethora of online answers to this.
Diesel derating with altitude
Per Ardua Ad Astra
07/27/2011 8:25 AM
Try:http://cumminspower.com/en/cummins/
Register to Reply 4 comments
Anonymous Poster (1); aurizon (1); PWSlack (1); W9GFX (1)
