Previous in Forum: Refrigeration: mechanical eng   Next in Forum: Burner for Kerosene/Diesel Oil Water Boiler
how to make a motorized pendulum mallet
07/27/2011 10:31 AM
Hi all,
I hope I've come to the right place. I need to make a large scale pounding mallet that can repeat a pound every 5 seconds or so. I'd be using a mallet approximately 300mm in diameter. It would pound away at a large cube of compounded dirt - a mud brick of sorts - that is roughly 1.5sqm or so.
So, I hope it could come out looking a little like this -
http://www.electronics-lab.com/blog/?p=6799
I also assume that some weight bar will be required on the end of the mallet stick to allow for a pendulum like motion.
If I've come to the wrong place, sorry. If not, I hope you can help. So sue me for being an artist.
Best
Re: how to make a motorized pendulum mallet
07/27/2011 11:07 AM
Here's a link to your picture.
I think you're in the right place, but if you give more detail on what, exactly, you are trying to accomplish, there's a good chance that someone can give you a much more efficient way to do it.
07/27/2011 11:21 AM
Attach a motor/gearbox with an arm on the output shaft that contacts the top of the pendulum arm and causes it to move backward to a point that the arm is released and falls toward the "brick". The arm rotates through 360° each revolution, but is only in contact with the pendulum long enough to move it back and then drop it.
Of course, you don't need the servo and propeller.
Register to Reply 2 comments
