Hi, is there any special type of surge protector I should use for a treadmill its a powerful one. Not sure about the horse power rating. If so which type should I use. Thank you...
its very annoying, do you think i should ask the shop if there is anything wrong with it? or is it normal? FYI its a powerful machine with a 3HP motor and it only seems to trip when i use it for 1 hour or more.
if it keeps tripping the fuse then the treadmill is just a mean son of a bitch! ha!
but seriously, where are you? what is your mains voltage? 3HP equates to around 2.2kW, at 240 volts you're around 9 amps. what else is sharing that circuit/power point? if you turn off the 72inch plasma tv does it still trip? is it the circuit breaker or the earth leakage tripping? stick a megOhm meter on the treadmill and see what you get. ... call an electrician?
Everything works out in the end, just not neccessarily how you want
