Previous in Forum: final year project   Next in Forum: Calibration
4-20mA Simulating vs Sourcing
07/28/2011 9:06 PM
When will you simulate 4-20mA as oppose to sourcing 4-20mA. I notice some of the calibration instruments gives you a choice to use one or the other.
Re: 4-20mA Simulating vs Sourcing
07/28/2011 11:57 PM
I don't think there is anything "vs" or "opposed" between simulating and sourcing. Do you mean sinking vs sourcing?
07/29/2011 5:25 PM
The difference is not as clear cut as one might think.
You can simulate a transmitter by sourcing current if the transmitter powers the loop. Typically known as a 4 wire transmitter where power is not supplied to the transmitter through the 4~20 mA output.
You can simulate a transmitter by sinking current if the instrument or an external source powers the loop. Typically known as a 2 wire transmitter where power is supplied to the transmitter through the 4~20 mA output.
As a general rule:
When the 4 to 20 mA loop is powered by the transmitter, use source to drive a signal back to the instrument.
When the 4 to 20 mA loop is powered by the instrument, use sink to drive a signal back to the instrument.
This seems the best I can do on a sleepy Friday afternoon!
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Register to Reply 2 comments
