Previous in Forum: Combiflex Relay   Next in Forum: Use of Aluminium Wire Armour for Single Core Cables
Clearence Between Cable Ducts
08/02/2011 4:29 AM
Dear friends,
I want to make some cable ducts in our boilier area for the construction of the new boiler. We have one MV cable , some LV cables and some control cables. So i want to know that these cable ducts can we make near by or any distance between these cable ducts. Suppose we want to make the distances what is the clearence between these ducts as per IEEE. Expecting your valuable commands.
Re: Clearence between cable ducts
08/02/2011 4:34 AM
Thou shalt make sufficient clearances between these cable categories. Consult NEC, BS, IEC, IS, etc., according to whatever your local code is.
Good Answers: 170
08/02/2011 6:22 AM
300mm would be ideal as per IS 1255.
Good Answers: 170
08/02/2011 6:22 AM
08/02/2011 6:31 AM
300mm would be ideal as per IS 1255 (now that I've heard it twice.)
Maybe 300km would be even better?
Reply Score 1 for Off Topic
Re: Clearence Between Cable Ducts
08/02/2011 10:47 AM
If you are making separate ducts then all that is required is base on convenience of maintenace.In the same ducts also with sufficient clearance cables of Different voltages can be laid
electricalexpert65 (2); nesubra (1); Tornado (2)
