Previous in Forum: Requirement of Crusher   Next in Forum: Surface Grinder
difference between PLC and BCU
08/02/2011 9:24 AM
what is the difference between PLC and BCU(bay controller unit)?
Re: difference between PLC and BCU
08/02/2011 9:28 AM
Please describe the BCU.
08/02/2011 9:40 AM
BCU is called Bay controller unit.This device is used in Substation for controlling Circuit breaker, isolator , relay from local and also from remote(SCADA) end.
08/02/2011 9:47 AM
Then the answer is "very little".
08/02/2011 9:54 AM
I'd suggest that a BCU could be implemented with a PLC, but a BCU is not necessarily a PLC. Do you see the distinction?
A PLC only becomes a BCU when connected to all the other components in the correct configuration, and when correctly programmed. A PLC could also be an LCU (lighting control unit), a TCU (temperature control unit), or any number of other "CU"s.
Register to Reply 4 comments
amitabha0107 (1); JohnDG (1); PWSlack (2)
