Previous in Forum: Vibration and Noise Control in Cavitrol Trim Globe Control Valve   Next in Forum: Water Hammer or Impulse Calculation
Conversion of Heat Unit
08/03/2011 8:59 AM
how to convert 241.8 kJ/g-mol (at 298.15 K) or 0.0672 kWh/g-mol to BTU/Hr/Kw
Re: Conversion of Heat Unit
08/03/2011 12:53 PM
What is the unit Kw?
08/03/2011 1:30 PM
Kilowatt
08/03/2011 3:09 PM
  1. You need to keep your unit designations consistent. There is no way you can be sloppy here without confusion. For kilowatts, it should ALWAYS be written kW, not Kw.
  2. Your units of BTU/Hr/kW does not make sense: Both BTU/Hr and Kw are units of power. This gives you power/power, a dimensionless expression.
  3. Your initial units of kJ/g-mol and kWh/g-mol are energy/mass. To convert them, the end units must be in the same configuration (take some time to ponder this).
Either you did not represent the end units correctly, or you are trying to do something that is impossible.
I suggest that you repost your question and take your time to make sure it is right. If you want to understand this, it is no time to be lazy.
Good Answers: 137
08/04/2011 9:25 AM
Better still, work in the SI system, then there's no need to convert (to BTU/lb-mol, presumably)
Codey
08/04/2011 11:45 AM
I really wish we would. I hate having all these conversion factors in my head! It's too full already!
We coat adhesives and do lamination of roll stock. To determine the correct amount, we get the coat weight by weighing a piece of paper, sticking it on the web, pulling it off with the adhesive on it, and weighing again.
We use a paper cutter with inch rulings and a balance that reads in grams. Thus we have the cool mixed units of g/100in2.
08/03/2011 1:01 PM
I suggest you go here to learn how to do this:
http://www.dummies.com/how-to/content/how-to-convert-metric-units-of-measurement.html
Happy studying!
Register to Reply 6 comments
Bharat Jadeja (1); Codemaster (1); Mikerho (4)
