Previous in Forum: Mechanical Engineering - Ventilate an Underground Tunnel   Next in Forum: Impact Testing
Kiln Power
08/05/2011 5:14 AM
kiln running at 200 tph at 4.0 rpm with very disturbed burning zone ,what may be the reason while changing its rpm to 1.5 & feed at 110 tph, KW of the kiln motor(vfd operated) decreased to 8 kw, although after proper kiln operational steps its KW got normal & running very fine.can any one answer me the reason?
Re: kiln power
08/05/2011 5:21 AM
For a brief period, the motor had to lift more material into the tumbling zone than it would have done at the earlier speed.
Good Answers: 181
Re: kiln power
08/05/2011 5:53 AM
If you watch the burden in a rotary kiln you will see it lift on the kiln side and then tumble back, a bit like waves on a beach. Increase the speed and burden then as you said yourself it becomes very erratic.
What is the rated throughput of the kiln?
Re: Kiln Power
08/11/2011 12:23 PM
4 rpm seems very High for this application 1.5 to 2 is much more stable.
Is this a kiln for making portland clinker?
Register to Reply 3 comments
pipeit (1); PWSlack (1); TonyS (1)
