Previous in Forum: Pump Selection   Next in Forum: Calculation of Torque for Design of Drive Gear
23 comments
Gas Calculation
08/08/2011 2:59 AM
If natural Gas reading is 11678 M3 at mass flow meter , ambient temperature is 35 C and working pressure is 0.8 bar then what will be Nm3 by calculation . Can some one calculate for me. Thanks
Re: Gas calculation
08/08/2011 5:34 AM
Take the ratio of absolute temperatures and multiply.
Take the ratio of absolute pressures and multiply.
That will get close enough for all practical purposes.
http://en.wikipedia.org/wiki/Ideal_gas_equation
Good Answers: 137
Re: Gas Calculation
08/08/2011 9:32 AM
You say it's a mass flowmeter. If it's reading m3, it will have been calibrated to some standard temperature and pressure, pressure almost certainly 1 atmosphere. You need to find the calibration temperature. If it's 0°C, you're already in Nm3. If it's something else, convert as #1.
Codey
Re: Gas Calculation
08/11/2011 11:38 PM
Dear Muhmmad
Volume at NTP = 11678 x [273.15/(273.15+35)] x [(1.013+0.8)/1.013] = 18,526.6 Nm3
I have calculated it for you. For more accurate result you need to include compressibility factor which is in this case I assume to be equal to 1.0 (normally valid for low pressure system).
Hope you are happy with the answer
Best regards
Good Answers: 137
Re: Gas Calculation
08/12/2011 8:08 AM
No, we were told it is a mass flowmeter. One such is a thermal hotwire type. Please read my #2. If the mass flow stays constant, the reading does not change with pressure and temperature. It can be set up to read mass flow or volume flow. OP said m3, so volume flow in this case. It can be calibrated to read flow corrected to any chosen pressure and temperature, but in practice it is likely to be calibrated to one of the standard conditions. Most common are normal (0°C, 1 atm), or standard (15°C, 20°C or 70°F depending on your preference, and 1 atm). If Muhmmad doesn't know what it's calibrated to, he needs to find out.
If it's calibrated to normal, 11678 m3 is already correct. If it's one of the standards, multiply by 273.15/(273.15+T) where T = 15, 20 etc, but not the actual gas temperature. Just noticed he said ambient temperature 35°C. That's even less relevant than the gas temperature.
Codey
Re: Gas Calculation
08/13/2011 5:09 AM
Dear all
Thanks for showing concern and helping me to resolve the Natural Gas calculation issue.Hopefully this will help me lot and I will follow the same method for calculation in future.In case any problem I will come to you again and will get the soloution, Inshahallah.Thanks once again for your concern and support.
Best Regard
Basharat
Good Answers: 137
Re: Gas Calculation
08/13/2011 7:10 AM
Hang on, you've had conflicting advice from me and other posters. We can't all be right. I believe my approach is correct, if it is a mass flowmeter as you said in original post. Can you confirm and give more details of the flowmeter?
Codey
Re: Gas Calculation
08/14/2011 5:02 AM
Dear Mr Cody
Thanks for the concern.Working detail of the meter I am mentioning here. This is all mentioned from manufacturer, (Incase an total burner control, there is a gas flow meter with analogue output signals in the corresponding gas pipe.The mass flow meter measure the individual amounts of gas in the burners and control them with the control valve.
Calculation from operation flow(m3b/h) to (m3n/h) will be the electric signal from gas mass meters, the pressure, and the temperature sensor.)the calculation of this meter is doubtful that's why I made request for calculation because me and my collegues calculated many time with the formulation(P1v1/T1=P2V2/T2)
P1V1/T1 = P2V2/T2
P1= pressure at normal condition.i.e..1 atm or 1.013 bar A
T1= Temperature at normal condition.i.e..288.5 K.( 15.5 +273.0)
V1= Volume at normal condition in M3/h or M3/min.....
P2= pressure at standard condition.i.e..1 atm or 1.013 bar A
T2= Temperature at standard condition.i.e..273.0 K. 273 is absolute zero.
V2= Volume at standard condition in M3/h or M3/min.....
With this formulation ,the result is not matching with soft ware calcultion and this situation is confusing.
Today reading at mass flow meter is, 11883 m3
Temperature is indicating 38 C
Pressure is . 0.8 bar
Hope this all information is enough to find the result.I am greatful for your concern.Wating for your advise.
Basharat
Good Answers: 137
Re: Gas Calculation
08/14/2011 11:23 AM
Muhmmad
You still haven't given details of the flowmeter. What manufacturer, what model, what does it look like, etc? What are the calibration conditions?
If it is a mass flow meter you don't need to measure the temperature and pressure to correct to normal (or standard) conditions (as I've said a couple of times!). You need T & P if it's e.g. a differential pressure type meter.
You say "Calculation from operation flow(m3b/h) to (m3n/h) will be the electric signal from gas mass meters, the pressure, and the temperature sensor". What is m3b/h? I assume m3n/h means normal (usually written Nm3/h).
Your formula P1V1/T1 = P2V2/T2 is only correct if you know it is reading accurately in standard (15.5°C) m3/h and you want to convert to Nm3/h.
Do you mean the signals from the pressure and the temperature sensor are fed into the controls and used to calculate normal flow? (assuming it's a ΔP type) or do they give readings which you are using to calculate manually? If they go into the controls the reading should be correct. There would be no need for conversion as you've asked for. It would be a case of making sure everything is working right, and the formulas in the controls are correct.
If T & P do not go into the controls, the flowmeter may have been calibrated to read normal (or standard) when the actual T & P are at estimated average values. That minimises the error due to T & P variations, and if they don't vary too much the result could be near enough in practice. But you would need to know what those values are in order to check.
A final point - why do you want to measure gas flow? Is it to check gas usage, or for boiler control? The boilers I've seen just modulate the gas control valve based on water output temperature, no need to measure or control the flow to a setpoint. Your boiler might be different.
Codey
Re: Gas Calculation
08/16/2011 7:10 AM
Dear sir
The detail of flowmeter is mentioned here.
Q max = 1000 m3/h
Q min = 50 m3/h
P max = 10 Bar
T = -20 c to + 60 c 1 m3 ^ 1 1mp
ELESTER
ii : Yes signals from pressure and the temperaturesensor are fed tocontrols and used to calculate NM3.That reading is confusing.Actually this Glass plant and we need to calculate cals/kgs.and melting efficiency is very important.
This is Natural Gas and Molicular weight is 19.5
Hopefully this information will help to sort out the problem.
Today reading at flowmeter is 12167 m3 Temperature is 36 c and pressure is 0.8 bar
Best regard
Basharat
Good Answers: 137
Re: Gas Calculation
08/16/2011 2:04 PM
Need more information on Elster. According to web they make various types of gas meter, but from a quick look I think they all measure actual m3. BK diaphragm type, QA turbine type and RVG-ST rotary type. Is it one of these? Can you give more details?
The actual m3 reading is then (presumably) converted to Nm3 by the software, using formula you've given. So the flowmeter itself does not give mass flow (or, equivalently, normal flow), but the system as a whole does.
I'm not clear what the problem is. Do you have a direct reading from the meter, before conversion (actual m3) from which you calculate normal m3, and get different answer from the software's? If you do not know actual m3 you cannot calculate Nm3 so do not have a figure to compare with the software figure.
Codey
Re: Gas Calculation
08/17/2011 5:06 AM
Dear Sir
This is QA turbine type flow meter.The model is Q75 and in the list of Q75 ,open QUANTROMETRO Q (P).this PDF file is carrying complete detail of this flow meter.
ii:- I am getting two readings , one on flow meter in M3 and other on pc in Nm3 after calculation by the soft ware.My problem is that the reading I am getting in Nm3 is not matching with formula calculation. Because of this fuel efficiency cannot be calculated correctly.This is the reason ,I am seeking help to find out the correct answer.Difference of soft ware calculation is varying from 1.5 to 1.7 time where as formula calculation is giving difference only 1.2 to 1.3 time.
Today reading is 12067 M3
Pressure is 0.8 bar
temperature is 37 c
Hopefully you will find the soloution.
Regards
Basharat
Good Answers: 137
Re: Gas Calculation
08/17/2011 2:07 PM
It looks to me like the software is correct. Conversion factor from actual to normal is 273.15/(273.15+35) x (1.013+0.8)/1.013 = 1.59 (for 35°C), as given by sabriahmad in #3 (after removing superfluous brackets! Right in the middle of your 1.5 to 1.7.
Please give your calculation which yields 1.2 to 1.3.
Codey
Re: Gas Calculation
08/17/2011 8:43 PM
Dear Muhmmad
Would you please show your calculation.
Good Answers: 137
Re: Gas Calculation
08/21/2011 10:47 AM
Come on Muhmmad, we're still waiting for your calculation!
Codey
Re: Gas Calculation
08/22/2011 7:04 AM
Dear Sir
Sorry for delay. What I calculated , is mentioned as under.Please find the mistake and correct it.Hopefully this time my problem will resolve.
Best regard
V1/V2 = P2 X T2 / P1 x T2
P1 = Pressure at normal condition = 0.8 bar
T1 = Temperature at normal condition = 273 + 15.5 = 288.5 Kelvin
V1 = volume at normal condition = 512 m3/h
P2 = pressure at standard condition = 1.013 bar
T2 = Temperature at stranded condition = 273 + 33 = 306 Kelvin
V2 = volume at standard condition = 512 M3/h
V1 / V2 = 1 M3
P2 x T 1 = 1.013 x 288.5 = 292.2505
P 1 x T 2 = 0.8 x 306 = 244.8
292.2505 / 244.8 = 1.19383374183
512 x 1.19383374183 = 611.242875816 NM3
In 24 hours.
611.242875816 x 23.5 = 14364.2075816 NM3
Re: Gas Calculation
08/22/2011 8:52 PM
Dear Muhmmad
Your calculation is incorrect. My observation is that you are confused with the definitions of NORMAL and STANDARD conditions.
NORMAL conditions is defined as P = 1.013 bara, T= 0C or 273K
STANDARD conditions P1 = 1.013 bara, T = 15.5 C or 288.5 K
Data recorded by the turbine flow meter is at ACTUAL conditions
Flow rate at ACTUAL conditions:
P1 = 0.8 barg = (0.8 + 1.013) bar
T1 = 33 C = (33 + 273) K
V1 = 512 m3/h
512 m3/h is the actual flow rate, sometimes we denote it by ACM/h or AM3/h
Flow rate at NORMAL conditions:
P2 = 1.013 bar
T2 = 0 C = (0+273) K
V2 = 512 X (0.8 + 1.013) X (0+273)/1.013/(33+273) = 817.5222 NM3/h
The ratio between NORMAL and ACTUAL conditions:
V2/V1 = 1.6
The total volume over 24 hrs = 817.5222 x 24 = 19,620.5 NM3
(I am wondering why you multiply by 23.5 hrs?)
Volume at STANDARD conditions
V3 = 817.5222 x (15.5 + 273) / 273 = 863.938 SM3/h
By the way, what is the software reading?
Re: Gas Calculation
09/08/2011 4:38 AM
Dear Sir
Thanks lot for guiding me on right path , your calcultion is almost same what soft ware is calculating.I am sorry for dealay in answering.I was away for Eid.You asked me ,why I am calculating with 23.5 hrs, actually it is more less time because this is a glass plant and we are using regenrative system with two chambers and gas firing at one end is 20 minuts and then it reverse to other chamber for 20 minuts and during reversing their is no gas firing and that time is almost more then two minuts.In this case ,their is no gas consumption for two minuts after every 20 minuts.I am great full both of you for proper guidence.Hopefully you will help me again when I need you.
Best regards
Basharat
Good Answers: 137
Re: Gas Calculation
09/08/2011 7:08 AM
.... , your calcultion is almost same what soft ware is calculating...
Yes, I said that way back in #13
Codey
Re: Gas Calculation
09/10/2011 2:10 AM
Dear Sir
Yes ,you are right.You indicated in your convesation #13 ,soft ware calculation is correct but the way I was calculating ,not letting me to digest that but your patient and coperation made my calculation correct too.I am great full.Thanks once again.
Best regard
Basharat
Good Answers: 137
Re: Gas Calculation
09/10/2011 9:52 AM
No problem, hope you had a pleasant eid
Codey
Good Answers: 137
Re: Gas Calculation
08/23/2011 7:51 AM
There are so many mistakes here I don't know where to start. But 2 points - you need to work in absolute pressure, and if your converting between actual and normal m3, there's no need to bring standard temperature (15.5°C) into it.
Please read other posts in detail and have a good think about it.
Codey
Re: Gas Calculation
08/14/2011 8:22 PM
Salam Muhmmad,
If it is a mass flowmeter, then what is the reading in mass e.g kg/h? what is the gas molecular weight?If you know the mass flowrate, divide it by the molecular weight and multiply by 22.414 to arrive at Nm3/h.
The reading of 11883 m3/h is it actual volume at operating conditions (T=38C, P=0.8 barG) or at standard conditions (T=15.5 P=1 atm)? and you want to convert to volume at NTP (T=0C P=1 atm)?, you need to tell us more about your problem. Probably the manufacturer include molecular weight into the calculation? If that is so the equation should be:
P1V1/Z1M1T1 = P2V2/Z2M2T2
Where Z is the compressibility factor and M is the mol wt.
Perhaps you could give us a more clearer picture of the whole situations, so that we can help you once for all.
Wassalaam.
Sabri Ahmad
Re: Gas Calculation
08/17/2011 9:41 PM
Dear Muhmmad
After going through your data, I notice that you are using T1 as 288.5K. By definition, normal conditions is referred to 0C or 273K and P 1 atm. You are using 288K and 1 atm respectively.
For turbine meter, the figure given by turbine is actual volume rate at operating conditions (e.g P=0.8 barg, T=35C). However, you are not using these data in your calculation.
The equation you use is correct but the figures for pressure and temperature are incorrect.
Please recheck your calculation.
Best regards
Register to Reply 23 comments
Codemaster (10); Muhmmad Basharat (7); PWSlack (1); sabriahmad (5)
