Previous in Forum: Connection Type in High Rating Three Phase Motors   Next in Forum: Gas Calculation
18 comments
Pump Selection
08/08/2011 2:38 AM
How to choose the right industrial water Pump?
Re: Pump selection
08/08/2011 3:33 AM
The flow rate and duty cycle are a good start.
Re: Pump selection
08/08/2011 4:20 AM
Don't forget the delivery pressure requirement!
Re: Pump selection
08/08/2011 4:35 AM
D'oh
Good Answers: 53
Re: Pump selection
08/08/2011 10:28 AM
Congratulations !! , you have the Title of highest number of post for now. Keep it up.
(English cats are always faster.)
Re: Pump selection
08/08/2011 10:41 AM
What about Kris?
Good Answers: 53
Re: Pump selection
08/08/2011 11:01 AM
Of-Course another English cat, But records at this moments suggest that She is at 11551 Post, (Courtesy Bath braking techs.) thats not far from you.
Good Answers: 19
Re: Pump selection
08/08/2011 10:57 AM
I now doubt the counter meter . (No hard feelings PW Slack, but i feel you sit all day on CR4 ) you are addicted.
Good Answers: 53
Re: Pump selection
08/08/2011 5:09 AM
Hurry up, PWSlack is very near to the Crown, (Just 2 feet behind of cat.)
13278-13276=2
Re: Pump selection
08/08/2011 7:38 AM
Yeah, but just look at my GAs <smug mode on>
Re: Pump selection
08/08/2011 10:18 AM
I'll bet Anonymous Hero isn't impressed.
Good Answers: 53
Re: Pump selection
08/08/2011 10:20 AM
Yes Its good to be in smug mode, Otherwise its never ending. well done you kept that crown for so long with dignity.
Re: Pump selection
08/08/2011 3:36 AM
This can be a quite complex question.
Start with how much flow you need, and at what pressure. Many/most combinations of these will lead to a centrifugal pump selection. [High pressure moderate flow may require multi-stage centrifugal, piston, progressive cavity, regenerative turbine, or other special types; high flow low pressure might lead to an axial (propeller) pump choice.]
If solids are present in the water, the passages of the impeller must be large enough to allow the solids to pass through, or else the pump must have a way to chop the solids to small enough pieces. This applies especially to sewage or sump pumps.
The shaft seal can be either a packing gland (small leakage) or a mechanical seal (no leakage unless the seal fails).
And this is only a start....
Re: Pump selection
08/08/2011 6:02 AM
Here is the big question
Ineed 15 l/h to 30000 l/h at 40 meter dinamic pressure.
im going to use a variable speed ac drive to get a stable flow and pressure
Re: Pump selection
08/08/2011 3:46 AM
Call three different pump suppliers. Tell them you need a pump, but you do not know how to select it. Answer the questions they ask. Then buy what they recommend.
Re: Pump selection
08/08/2011 6:56 AM
For that range of flow, speed control will be highly inefficient from an energy perspective and will create significant instability for control at the lower volumes.
We have water supply systems for towns and portions of the city that do experience that sort of variation at that sort of pressure and we achieve this with pumps capable of maximum demand volume (actually at least 200% capability) and a reservoir. We maintain reservoir between 90 and 95% full. That way, pumps get to be run at efficient speeds, relative pressure change is less than 1m head, and low flows are easily supported.
For instance, a centrifugal pump capable of 30000l/hr would have material backflow through the impeller when speeds are low enough to supply 15l/hr.
Not favouring any particular pump suppliers, but brands like AJAX, ITT Flyght and ABS come to mind in recent transactions.
Good Answers: 19
Re: Pump Selection
08/08/2011 9:54 AM
"When in doubt ask"
Call a reputable pump manufacturer's engineer and ask him to select the pump for your required application. When he does that then ask him how? then ask him to show you? Before he leaves take his pump catalog indicating the capacity & sizing chart.
write all . go home review all what you have written, work out on different examples and you will learn.
If you cannot learn then do not bother yourself and then rely on the pump engineer.
Good Answers: 48
Re: Pump Selection
08/08/2011 10:51 AM
Is the head fixed, at 40 meters?
A variable speed AC drive is the most efficient way to get the flow and head you require. However, it will not come anywhere near to the flow range you are looking for. It is adviseable to operate a centrifugal pump within the range of 20%-140% of BEP (Best Efficiency Point). It is very difficult to maintain stable flow and pressure below about 20% as most curves are quite flat (or even humped) at this point, and ultimately it can damage the pump. With a single pump and speed control you might, at best, get a 15:1 turndown ratio, and you are looking for 2,000:1.
If you cannot use a reservoir system, as proposed by Just an Engineer, then there are a few other options:
1) External recirculation (from pump discharge to source) of a proportion of the pump flow (up to 99.25%!), possibly in conjuction with control valves. This is the least efficient method at low flowrates, but possibly lowest initial outlay.
2) Use three seperate pumps, with speed control (and/or control valves), to cover the range.
3) Any combination of the above.
Re: Pump Selection
08/28/2011 2:00 PM
Dear Mr.Claudio,
Your question is General in nature, and lot of explanations are available.
Pump Selection depends upon Flow Required, Head, Viscosity of fluid, Temperature of fluid, NPSH (If very hot fluids are to be pumped) Type of Suction - Flooded suction or Negative suction, etc. shut-off pressure and leak-off connection size etc.
Pl. describe your requirement and you will get good response from CR4 MEMBERS.
Alternatively - search in this forum itself.
Rajeswari.
Register to Reply 18 comments
CLAUDIO (1); ducon (2); Holzfeller (1); Just an Engineer (1); lyn (3); PWSlack (1); rajeswari (1); rakesh_semwal (4); Tornado (1); user-deleted-1105 (3)
