Previous in Forum: Von Mises Stress   Next in Forum: Application and Advantages of Ball valve,Diaphram valve,Butterfly valve
HVAC
04/19/2007 1:58 AM
Dear sir
which valve is better for isolating in HVAC system Gate or butter fly valve .
T.U
Good Answers: 19
Re: HVAC
04/19/2007 3:42 AM
Gate. Butterfly will tend to leak. Ball Valve better option for butterfly.
Re: HVAC
04/19/2007 4:33 AM
It depends on the size and construction of the pipeline and the fluid inside it. For the smallest lines a bronze gate valve is 'cheap as chips', though the need to rotate the handle a number of times to get from open to closed may be an unattractive feature. A ball valve with a 1/4 turn from on to off may be more attractive, though of more initial value. Above, say 2in (50mm) diameter the butterfly valve starts to become attractive for the same 1/4 turn criterion; though a pair of flanges are required now, one either side of the valve, it may be a more appropriate solution than a ball valve, as now the ball is becoming quite heavy and the valve to contain it likewise. Plastic pipelines tend to gravitate towards ball valves and diaphragm valves; the value of a 4in (100mm) valve is little more than the value of a 2in (50mm) one.
What does the operation's local piping standard say on this matter?
For isolating a system for maintenance purposes, it is usual to lock valves and insert a spade in the pipeline at a sutable point under a Permit-to-Work system; valves are not considered a reliable-enough shut-off arrangement to assure downstream personal safety in most industries.
Good Answers: 19
Re: HVAC
04/22/2007 3:26 PM
You asked this question again. Check my reply on top.
