Previous in Forum: Difference Between a Switch, Relay, Circuit Breaker and Contactor   Next in Forum: REF Stability Testing for Delta/Star Transformer?
Term Gain for Amplifiers and Efficiency for Transformers
08/11/2011 7:12 AM
helo
can anyone help me from this confusion i m having that when we talk of amplifiers we say amplifier gain and when we discuss transformers we say transformer efficiency while both gain and efficiency are based upon input and output relationship.
waiting for replies
thanks
Re: why we say the term gain for amplifiers and efficiency for transformers
08/11/2011 7:20 AM
Amplifier gain = Output/input
Transformer Efficiency = Output/input
But there is a hidden agenda- In amplifier the energy is increased (you have a secondary power pumped in) But that is not the case in transformer.
Good Answers: 918
08/11/2011 7:26 AM
Transformers are passive components. The ratio of windings between the primary and secondary windings can step up or step down the AC voltage on the primary side.
However, like any passive system there are losses. The more signal loss, the lower the efficiency of the transformer.
There is a lot more to this than that, but discussing transformers in a complete and meaningful way is a big subject in itself and there are books on the subject.
Understand that transformers do not produce gain. While you might be able to step up an AC voltage to a higher potential, you also produce proportionally less drive current minus any insertion loss in the transformer.
You can easily "feel" those losses if you put your hand on a working power transformer. It will be warm or in some cases even hot.
Good Answers: 266
08/11/2011 7:57 AM
Because your talking about two different devices. In their use the amplifier we would want to know it's gain how much it amplifies the signal. On a transformer is efficiency or how well transforms the power.
India - Member - New Member
Good Answers: 164
Re: Term Gain for Amplifiers and Efficiency for Transformers
08/11/2011 9:02 AM
As has been said in different words by experts here....
An Amplifier amplifies an input, but has some power available from elsewhere. eg: an audio amplifier.
A Transformer transforms power from one level of voltage and current to another. It has no access to any other power source except the input.
Why think of these two devices together? They are quite different...
08/11/2011 9:03 AM
Transformer Efficiency is actually = Output power /input power, it is a measure of how efficient power is being transferer from primary to secondary side, it is always less than 1 (100%).
Amplifier gain can be voltage gain or current gain, can be more or less than 1, can also be negative value.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Anonymous Hero (1); Anonymous Poster (1); bravo88 (1); kvsridhar (1); ozzb (1)
