Hello you all.
I am facing a new problem today, one of our welding machine has it output shifted to the "ground". I explain, using a multimiter with the black lead to the ground or more specifictly the 'rig body', i measured ~ 0Vdc on the + post and -55Vdc on the negative post.
At first i tought that someone attached a ground lead on the positive side of the welding machine. (The machines are hard wired to a distribution network permanently install all over the rig). After looking all around the place i decided to use my head and start at the machine...
And then i disconnect the positive lead from the machine and i still have the same reading... Positive lead approx. 0 Vdc to ground and minus 55 or so Vdc on the negative lead. I made sure that the supply is fine in regard to ground fault, all three phases read approx. 275Vac to groung which is OK as you know.
I just decide to drop a line to you i can to the office to get the oscilloscope to see if there is something to see...
One more thing who is strange is that the machine works fine if the work is not touching the body, let say on wood, so that tell me than the bridge itself is ok..
Thank you in advance.
