I forgot my password.
Don't have an account?
Dear Sir,
What is the Allowable stress for API 5L Gr. B at 170 F.? How we can find out this figure, As per ASME B31.3 It is giving as 100-200-300 ( Temp range) .
Thanks and Regards
Vani
You assume a linear relationship between the temperatures and interpret the table as such.
Table A-1 says it is 20 ksi at 100 deg F and 20 ksi at 200 deg F, what would be the value when the temperature is 170 deg F.
For example sake, if it says 20ksi at 100deg F and 15 ksi at 200 deg F, then at 150 deg F, the allowable stress value would be 17,5 ksi.
Use interpolation as demonstrated at that example: Pipe_Wall_Thickness_-_Problem_Solution.
Thanks for your answer and attachement.
Thanks and regards
Vani.
