Hi All, am new to this forum and would like to seek advise for the above mentioned subject.
For a TEMA-R exchanger, all flanges and extended tubesheet shall be of confined joint construction. An internal floating heads is commonly designed with a head flange having a 5mm step-in (see Fig RCB 5.141) to fullfill the confined joint requirement.
Instead of giving a 5mm step-in on the floating head flange, are we allowed to design using a confined gasket which the gasket core OD flushes floating tubesheet OD, while the gasket outer ring OD is extended to the stud bolt. The head flange therefore would not have a step-in gasket seating face, yet would be a raise or flat faced instead.
