Hi All,
Anyone can recommend a suitable mcu for the above?
I intend to use the mcu in an IO interface card that has either support rs-232 or usb(2.0). It best to use common part that can support both. It also has to work fwith VDD from 3.3V to 5V (since usb is 3.3V).
Most importantly, the mcu must be quite well documented (preferably w example C source codes for usb2.0 which is more complicatedthan rs-232).
For rs-232, I believe about 16 bytes is sufficientfor most baud rates. Does anyone know what is the typical memory buffer size for usb2.0 data transfer? Does USB has any flow control signals (such as cts and rts in rs-232)? Sorry to askbut Ido not want to caught in situation where the limited mcu memory slows down usb data transfer considerably. This IO interface card is to act as bridge between a user peripheral device and an ethernet or tcp-ip card/ which is in turn connected to the computer network, and the mcu is to bridge the communication between peripheral controller (which does not has connectivity option) with the ethernet/tcp-ip card.
Any advice would be greatlyappreciated.
Thanks!
