Previous in Forum: G.I. Conduit for Fire Alarm System Instead of uPVC   Next in Forum: Inductive and Capacitive Loads
8 comments
Transformer Protections
08/18/2011 7:30 AM
What are the Protections for Transformer?
Still now i know only relays:
27: Under Voltage Relay, 30: Announciation Relay,
50: IDMT O/C Relay, 50N: Instataneous O/C Relay
51: E/F relay, 51N: Instataneous E/F Relay
64: Restricted E/F relay
74: B/H relay, WTI, OTI Relay, (Relay No's: 86 , 94 and 95)
and OLTC and RTCC
I know only these relays any remaining protections also is there for protection of T/F.
Re: Transformer Protections
08/18/2011 7:45 AM
Fuses?
Anonymous Poster #2
08/18/2011 8:50 AM
Surge protection my friend.
08/18/2011 9:53 AM
theres also the Buchols relay... I am not sure if the name of this engineer is correct dough!
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Good Answers: 170
08/18/2011 10:56 AM
A few corrections:
27 is AC Undervoltage Relay
50 is Instantaneous Overcurrent Relay
50N is Instantaneous Neutral Overcurrent Relay
51 is AC Time Delayed Overcurrent Relay
51N is AC Time Delayed Neutral Overcurrent Relay
64 is Earthfault Relay (64R is Restricted Earthfault Relay)
74 is Alarm Relay
86 is Lock-out Relay
94 is Tripping or Trip-free Relay
95 is Assigned for devices where none of the Device Function Numbers 1 to 94 are suitable.
Buch-Holz Relay shall be numbered 63;
Oil Temperature Relay shall be numbered 26T & Winding Temperature Relay shall be numbered 49T
This is as per ANSI C 37.2-1970.
And, as regards the protection of transformers, it depends upon the size & criticality of the transformer.
08/18/2011 11:54 PM
Dear Sir,
Thanks for your information it is very usefull to my bright career.
Thanks & regards,
Srinivas
08/19/2011 2:21 AM
you forgot the most important one, percentage differential protection - which operates for internal fault, but will not operate for through fault. A simple differential protection does not take into account of CT's inaccuracy due to difference in magnetic saturation characteristic of field winding - which is more pronounsed during transient conditions.
sks
(serving humanity)
Good Answers: 170
08/19/2011 2:38 AM
Acting too smart! huh! So, you think that differential protection is 'most important' for transformers! Would you provide it for any size of transformer, say 100kVA? What I have done is to correct the ANSI Code explanations, which were wrongly mentioned by the OP. Moreover, the OP has not specified the size of the transformer. Haven't you read what I have mentioned at the end of my posting that the extent of transformer protection depends upon the size and criticality of the transformer?
And, since you are trying to teach me 'percentage differential protection' - by the by, it should be "percentage biased differential protection" - let me ask you a question:
Generally, in transformer differential protection, one uses Class PS CTs, whose knee point voltage or the saturation level, is calculated duly taking into account all the worst case scenario parameters. Then why should one use a percentage biased differential relay?
08/19/2011 5:28 AM
To take care CTs mismatch during operation of protection.
Manindra
Anonymous Poster (1); electricalexpert65 (2); electronick (1); manindra (1); PWSlack (1); sauravbabu (1); vasu.srinu001 (1)
