Previous in Forum: Earth Link Between Two Metal   Next in Forum: Trend Master 2000
Impulse Tube
08/18/2011 9:09 AM
Hi All,
How many bending allowable for impulse tubing and what is the maximum length of lead.
Regards
Re: Impulse Tube
08/18/2011 9:16 AM
How flexible is this tubing and why is it made of lead?
Re: Impulse Tube
08/18/2011 2:31 PM
Hyuk yuk yuk!
Press for Rimshot.
Re: Impulse Tube
08/18/2011 1:00 PM
I'll try to answer the question I think you asked. The number of bends is not important as long as there are no kinks or blockages. Tube length should be kept to a practical minimum.
Remember, there is no flow here so the tube is more a plenum that a transport mechanism.
Good Answers: 109
Re: Impulse Tube
08/19/2011 4:34 AM
Please give some more information.
Is this intended to impulsively drive advanced (but very loud) aircraft?
What is lead in this device?
RHABE
Re: Impulse Tube
08/19/2011 10:18 AM
Normally there should be no more than 3 90 bends in any tubing run, but on loung runs you can use the convention of having no more than 3 90 bends every 60 feet.
As to the lead, depends on the size of the tubing.
If the tubing is over 60 feet you may need to use larger diameter tubing.
Good Answers: 176
Re: Impulse Tube
08/19/2011 11:25 AM
NEL has a comprehensive white paper covering the installation of impulse tubing for differential pressure flowmeters.
It can be downloaded here:
http://www.idc-online.com/technical_references/pdfs/instrumentation/Differential%20pressure%20meters_nel.pdf
Register to Reply 6 comments
Doorman (1); Iris (1); lyn (1); PWSlack (1); RHABE (1); vargaalex (1)
