Previous in Forum: Pipe Deterioration Formula   Next in Forum: Suspension Bridges
Compressive Strength of Steel Rubber Composite
08/22/2011 1:52 AM
How can i calculate compressive strength of a steel rubber composite ?
Re: Compressive strength of Steel RUbber composite
08/22/2011 1:57 AM
The rubber part would be the limiting factor, and you may be able to find data on the rubber. Alternatively, you might be able to set up some compression tests that would measure the compression of a defined area under a defined load.
08/22/2011 2:24 AM
Thanks for your quick reply.
i have technical data sheet for the rubber . Is there any particular formula to find out the for this ?
08/22/2011 5:08 AM
Somebody else has already done it. It's the stress/strain diagram.
Register to Reply 3 comments
PWSlack (1); shafeeque (1); Tornado (1)
