Previous in Forum: Short Circuit Device   Next in Forum: DG Set for Cold Storage Unit
DG Set for Welding Application
08/22/2011 4:38 AM
Sir,
Can any one please explain me how to select DG set for welding application?
Re: DG set for welding application
08/22/2011 4:49 AM
Start by defining the application.
Next, compare available packages to the application to prepare a short-list.
Third, select the one on the short-list with the lowest overall life cycle cost, and buy it.
Good Answers: 15
08/22/2011 6:33 AM
define the welding application - is it resistance welding? what is the peak demand? what is the demand cycle? what is the duration of the peak demand? what is the construction of the welding transformer - 2ph to 1ph - or 3ph to 1ph? is the DG to be a standby power source for intermittent use or regular continuous power source?
share the information of the application to get best recommendations . . . hold it secret to drive the discussion into side issues and flood mailboxes with notifications . . . life is full of choices . . . .
08/22/2011 8:59 AM
Sir,
Thank you for your reply. I want to know the calculations done for choosing DG set for welding application. The welding can be any type of welding like resistance welding or arc welding etc.... If you explained me with an example of welding load details and DG set choosing calculations it will be very useful for me.
Thank you.
08/22/2011 9:19 AM
It sounds like, for <...any type of welding...>, any type of DG set would do.
A comparison between the KrisDelTM one and the LynDoorTM one during trials would be worth reading...
Good Answers: 181
08/22/2011 9:44 AM
If I were you I'd do some reading about DG sets.
From your previous posts you just don't have a clue.
Good Answers: 170
Re: DG Set for Welding Application
08/22/2011 9:45 PM
Please download & read Generator Application Guides of Caterpillar and/or Cummins.
Register to Reply 6 comments
electricalexpert65 (1); murugesanmc (1); PWSlack (2); soebfatehi (1); TonyS (1)
