Previous in Forum: Solar Tracker Circuit   Next in Forum: Digital Relay Explaination
Liquid Level Control Relay
08/25/2011 3:39 AM
Good day friends
I need to have a two level relays output contacts alternating and independent and that neither by fractions of seconds are ON simultaneously. Those that know work well if these contacts are governed by the probes but if the power is cut off when you return there is a split second in which the output contacts are ON at the same time. Does anyone know any relay that solves the problem?? I thank you Anselmo
Re: Liquid level control relay
08/25/2011 3:48 AM
So, why not wire the power to each coil through the normally-closed contact on the opposite relay?
08/25/2011 5:21 AM
Register to Reply 2 comments
