Previous in Forum: Deep Well Motor Breakdown   Next in Forum: Torque Terminologies WRT to Motor Specifications
power electronics
08/25/2011 11:08 PM
hi this is purv mistry from INDIA-user
i am final year student of bachelor electrical engineering, so please suggests some of project comes under power electronic field.
purv mistry
Re: power electronics
08/26/2011 4:59 AM
A 3 phase Inverter for a 50 kW induction motor control , good enough for EV car should be very challenging and enriching project .
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Good Answers: 110
08/27/2011 11:49 AM
I agree completely. This is more interesting than, for example, an industrial inverter drive, where size and weight are less of a concern. There are existing automotive drives in this class, but they are expensive. Perhaps the project could focus on cost reduction. It would also be interesting to give thought to low voltage (<50V DC input) drives to enable battery packs to be less lethal (albeit requiring larger cables).
Think big. Drive small.
Good Answers: 59
08/26/2011 11:00 PM
There is plenty! Please check out the questions of maybe the last year. You will find plenty to chose from. Good luck with any.
08/27/2011 1:27 AM
google viper smps
hint you can get the thing to go way wider on the ac input if you place an inductor in the self power winding path. Look out for self inductance in your xformer.
Working to end the use of carbon for energy
Register to Reply 4 comments
bravo88 (1); K_Fry (1); leveles (1); regsoft (1)
