Previous in Forum: Fuse - Which Type for 160 Amps and 48 Volts?   Next in Forum: Selection of Motor Frame Size
India - Member - New Member
6Pin Relays Wiring Diagram
08/26/2011 2:04 AM
hi all,
can any one send me the wiring diagram of 12vdc/100ohm relay(6pin)
thnks...good day
rimpul
Re: 6pin relays
08/26/2011 2:25 AM
Where does the 100Ω figure in? Maybe the coil, in which case 12V/100Ω = 0.12A, and hence the coil consumes 12V x 0.12A = 1.44VA?
I would guess DPST (double pole, single throw), but without knowing whether the contacts are NO (normally open) vs NC (normally closed), a wiring diagram will be difficult.
Re: 6pin relays
08/26/2011 3:36 AM
the coil inside the relay is 100ohm
and regarding the contacts i am bit confused? so could u guide me which pin is used for load circuit and control circuit . how the 6pin relay internal wiring is?
Good Answers: 181
Re: 6pin relays
08/26/2011 4:42 AM
The only people that can help are the manufacturers. We will only be guessing.
It could be:
  • SP-CO (1 redundant pin)
  • DP-NO
  • DP-NC
All will configure to a 6 pin base
Re: 6pin relays
08/26/2011 4:51 AM
Look on the side of the relay! Most relays have a little diagram. You will find 2 contacts for the coil, and maybe two separate pairs of contacts that open or close when the coil is energised, or as stated, a redundant pin where you have a NC on one and an NO on the other with a common connection scenario!The Base the relay slots into may also give you some help (ie, A1,A2 for the coil)
Good Answers: 58
Re: 6Pin Relays Wiring Diagram
08/26/2011 11:16 AM
Here are some examples:
DPST (6 pin) above appears to be what you are looking for.
While maybe not exactly what you are looking for but you should get the general concept from the examples above.
Source
KJK/USA (1); Mr. Truman Brain (1); rimpul (1); TonyS (1); Tornado (1)
