Previous in Forum: Simple Variable Voltage Strobe Circuit   Next in Forum: Laser Cutting of 0.15mm Thick Aluminum Foil - High Speed
Load
08/31/2011 12:12 AM
I want to purchase new D.G set.
Connected load is 800kw, MD as per bill is 185 kw.
How to calculate load current peak & running current
Re: LOAD
08/31/2011 1:15 AM
What is "MD"?
Out of the 800kw connected load, not all may be running at once. You need to figure out the maximum concurrent load, plus a reserve for starting any motor along with whatever other loads are already running at the time. This can be complicated.
Re: LOAD
08/31/2011 2:50 AM
MD means Max demand during month.
Our load is moulding M/c,chiller compressor & auxillary.
How to calculate correct max current of total load?
Re: LOAD
08/31/2011 3:18 AM
With 800kw of connected load, it is very surprising to see only 185kw MD. (Why so much idle equipment?)
What is the "moulding M/c"? I understand "chiller compressor," but what is the "auxiliary"? These equipments should have current ratings (or kw ratings that with voltage can be converted to current ratings).
As mentioned before, you add up the current ratings of all equipment that could be running at one time, plus the starting current of the largest motor that might then be started. This gives the total load that the DG must handle. (All of this must be converted to uniform units, such as amperes, kw, or kva.)
Re: LOAD
08/31/2011 5:38 AM
Divide the kVA rating of the generator by the terminal voltage.
Of what significance is this number to the selection of cables and protective devices?
Register to Reply 4 comments
PWSlack (1); SAGA (1); Tornado (2)
