Previous in Forum: Mill Setting in Sugar Plant   Next in Forum: Fibre Index in Milling Section in Sugar Mill Definition and Formula
8 comments
Calculating Leak Rate Through a Crack
08/31/2011 5:15 PM
I'm trying to calculate the leak rate through an expansion joint. The only way I can immediately come up with this is by assuming the leak is essentially an orfice. But I'm concerned this is going to cause a major error in the result. Does anyone have any ideas on how else to calculate the leak rate through a crack?
Good Answers: 101
Re: Leak through a Crack
08/31/2011 6:26 PM
Is the medium a liquid or a gas?
If it's a liquid, can you simply place a bucket of known volume under the joint to catch the fluid, and measure the time it takes to fill the known volume, thus giving you the flowrate?
If the Medium is a gas it will be much more difficult, and you may need to employ some special instrumentation, such as transducers to measure a pressure differential, or flowrate before and after the crack.
Could you maybe enclose the joint area with a sealed bag or something to actually capture the gas as it escapes, and measure the volume in the bag after a given time?
08/31/2011 6:45 PM
It is flue gas from a coal fired boiler. I have static measurements for the duct and it is venting to atmosphere so I'm good there. The leak is actually theroretical and does not exist. I'm assuming an area that would account for a buch of small leaks. I'm just doing this calcuation to estimate how much flue gas is leaking out based on the assumed area. I'm needing to try to find a way to estimate a discharge coeffeicent that would be representative of a small crack rather than an orifice.
08/31/2011 11:50 PM
The amount of leakage is not only dependent on the duct static pressure, but the flue gas velocity, crack geometry, crack opening roughness, and duct thickness where the crack occurs. These last two may be negligible.
What's the purpose of this focus?
09/01/2011 8:19 AM
It is to submit what sort of emissions (particulate, CO2 etc..) could potentially be unaccounted for in the stack. Based on the crack geometry, roughness I'm trying to either figure out what sort of discharge coefficient would be applicable or some other method of finding the flow rate.
Good Answers: 137
09/01/2011 9:38 AM
For a given area, I don't think there'd be much difference between a crack and an orifice, and in any case the area you select appears to be completely arbitrary.
Flow is C*A*√(2*ΔP/ρ) (in consistent units) where C = discharge coefficient, 0.62 should be OK.
Codey
09/01/2011 1:33 PM
Thanks; That was the big question - whether or not treating it like an orifice is sound. I was thinking it would be vastly different, but was not sure.
Good Answers: 19
09/02/2011 6:38 PM
Get a cfm meter from Bacharach. I cannot understand what the hell are you going to accomplish even after getting the volume of the escaping flue gases (apart from CO that can cause harm). You should be working on how to utilize the flue gas for further waste heat recovery.
Good Answers: 19
Re: Calculating Leak Rate Through a Crack
09/02/2011 6:34 PM
change the expansion joint and help save us the nonsense exercise.
Register to Reply 8 comments
bbanks (3); Codemaster (1); ducon (2); Mikerho (1); RVZ717 (1)
