Previous in Forum: What Is the Equation that Governs the Pressure Wave Form of Trapezoidal Type?   Next in Forum: Designing Shear Bolted Joints in Fatigue Load?
Cooling Tower Capacity Calculation
09/02/2011 6:31 AM
Dear Friends,
I am having much more old FRP cooling tower & not having any technical detail like, TR capacity,etc. I am using it with cooling fan having motor of 5 HP, Entering water temp- 35Deg C, Input water line dia- 6". Its shape is square type.
You are requested to help to calculate capacity of this Cooling tower. I searched on net but I cant. If you need any further information, pl tell.
Thanks in advance.
Re: Cooling tower capacity calculation
09/02/2011 6:34 AM
  1. What is the dry-bulb temperature?
  2. What is the wet-bulb temperature?
  3. What is the flowrate?
The rest can be derived from them using a psychromatric chart.
Re: Cooling Tower Capacity Calculation
09/03/2011 5:02 AM
Dear Mr. SAN00,
In addition to the data required by other CR4 Members, Pl. provide the fan dia, and speed, and if possible fan blade angle at the tip and current drawn by the motor.
What is the Temp. of water at out let of the tower.?
RAJESWARI.
Good Answers: 49
09/03/2011 9:50 AM
The simplest method of estimating capacity is comparison of fan HP.
A typical 500-Ton tower has 7,500,000 BTUH (2200 kW/hr) reject at 1500 GPM flow (~6000 LPM) with 95F (35C) EWT and 85F (48.8C) LWT with a 78F (25.5C) WB entering air. Such a tower will have a 40 HP motor.
Tower capacity is directly related to airflow, and airflow is directly related to HP.
SO- a quick estimate would yield a capacity of 5 / 40 X 500, or about 60 Tons (900,000 BTUH (265 kW/hr).
Another cross check- less accurate- is pump HP. The 1500 GPM pump would be around 30 HP, so the pump in your case should be around 5 HP with similar tower capacity.
Hope this helps.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
09/03/2011 4:47 PM
Another way:K x (EWT - LWT) x Flow, where K is a constant depending on measurement units.
09/07/2011 8:10 AM
Hello friends,
Thanks for your reply.. Herewith sending more information
Dry bulb temp- 27 Deg C, Wet bulb temp.- 24 Deg C., Entering water temp.- 33 Deg C.
12/19/2011 10:26 AM
i think i know answer for your question
try out ask your question here frp cooling towers (this man is truelly proffessional in this buisness) he just halped me with my case...
Register to Reply 6 comments
coolingtowermaster (1); energygod (1); PWSlack (1); rajeswari (1); SAN00 (1); Tornado (1)
