Dear Friends,
PNG is now into prepayment metering system and doing away with the credit metering system.The problem we are facing from the prepayment meter is, When there is a power surge or system outage and the supply system is restored, the prepayment meter tampers. To reset the meter we had to get a token from the vending machines, key in the numbers into the meter thus it closes the tamper switch inside the meter.
The meter is operating on a 230 voltage supply to comply with AS/NZS standards
The meter only tampers when the cover is open, in this case the cover is still intact and sealed but the meter keeps tampering only on system outage.
What will be the cause of this fault, is it something to do with supply reliability or an electronic component that causes the meter to tamper?
If it is an electronic component, What is it?
Tom Tumun
PNG
