Previous in Forum: SS Welding Purge Gas   Next in Forum: A 53 Gr.A and API5L Gr.A Material
15 comments
Solar Dryers
09/03/2011 4:55 AM
Hi,
Advise us on how to make efficient,affordable, and high quality solar dryers, for mangoes.The dryer should be hardy and be able to cater for commercial needs hence giving quality end products.Aso advise on how to get dried mangoes that has the original sharp color without complomising the stadard health quality requirements.
Thanks,
vegan
Re: solar dryers
09/03/2011 10:23 AM
Let me guess. You hope to maximize your profit by having somebody here design for free your solar dryer. Well you might try this...
Good Answers: 11
Re: Solar Dryers
09/03/2011 12:41 PM
Remove moisture from air by lowering the temperatures, right after -bring dry air to solar heat exchanger then make the air blow or made contact your raw product...wallah..get somebody to figure it out the adjustments for you -a mechanical engineer.
add refined powederized sugar before drying..oppss...just try it.
Re: Solar Dryers
09/03/2011 1:12 PM
I read that all vegan food should be soaked in the urine of an old billy goat prior to drying - supposed to make it more tasty.
Good Answers: 114
Re: Solar Dryers
09/03/2011 2:56 PM
that would explain why Vegan's have that unique wang about them
I always thought it was the brewer's yeast
Re: Solar Dryers
09/04/2011 10:28 AM
Hi Garthh, Why the sarcasm, it is not really necessary!
Good Answers: 114
Re: Solar Dryers
09/04/2011 11:50 AM
when you support a unhealthy lifestyle [vegan] you better have a sense of humor
when you show up & ask for a solution, without much in the way of input, you better have a sense of humor
& finally Russ started it
Re: Solar Dryers
09/04/2011 12:10 PM
How come I always get blamed? Just because the post has my name on it I suppose
Nothing wrong with veggies - just by themselves, as Garth noted, it is not healthy - regardless of what people (scientists I suppose) claim.
Re: Solar Dryers
09/04/2011 12:39 PM
As an omnivore with many severe food allergies I feel that I should point out a fallacy here. Healthy food for one individual need not be healthy food for another individual. Similarly unhealthy food for one individual need not be unhealthy for another individual.
So unless you plan on starting some eugenic master plan, cut the vegan some slack.
Re: Solar Dryers
09/04/2011 2:38 PM
As an omnivore with no allergies I agree that not all foods are healthy for all people.
The OP is following his rights to be vegan.
I am following my equal rights to think the OP is off his/her rocker - plus he/she seems to be a freeloader.
I only cut slack where slack is due.
Good Answers: 114
Re: Solar Dryers
09/04/2011 2:45 PM
Hey I thought you were leaving?, it did make for a dramatic exit from the GW thread...
the organic thing has been co-opted by all the usual industrial players, it gets hard to separate the the fact from the hype
better results are going to be obtained using electric or natural gas fired dryers,
it's going to be tough to have real control with solar dryers & do any serious production, chances are this is an exercise in marketing 1st & formost
as you noted humans are omnivores...
Good Answers: 114
Re: Solar Dryers
09/04/2011 4:03 PM
I should probably have added that it is generally easier to have a working process, before using a much less versatile source of dry hot air like solar
walk before you run
Re: Solar Dryers
09/04/2011 12:56 AM
You need to do your homework first (with all due respect). Do Internet research to see if someone has written an agricultural thesis for the production of dried mangoes. You need to find out what the optimal temperature is to keep the product flavors intact. Also, you want to decide what your final percentage of moisture is going to be in your final product. In Hawaii we have a wide variety of Chinese perserved fruits "our term - crack-seed". My wife an I haven't bought dried mangoes for quite awhile because the moisture content is too dry. But don't base you decision on us, rather do you own market research in the areas where you decide to sell your product to see what their preferences are as to sweetness and moisture content. Most are preserved with some type of sweetener, be it sugar, aspartame, or whatever. Once you homework is finalized, you now have the requirements to ask someone to meet when making your drier.
Re: Solar Dryers
09/12/2011 10:02 AM
Some considerations to the solar dryer: It is similar to the problems with an oven - in the sense that you need enough surface area to process the whole batchload, and you need a design which will allow for only a very small variation in temperature among the racks, throughout all corners of the unit. Perhaps, (and I don't know this for a fact, but you may want to experiment) the loss in color is due to bleaching of the product due to ultra violet rays from the light source, as in the case of the sundried, outside exposure, or from the incandescent light source, when making test batches. A possible way to test this is to use a steel box heated by incandescent lamps which has louvered vents, or slits which allow the hot moisture laden air to escape without much of any UV light let in. You could try the concept on a small batch for testing purposes. Dry it to your requirements for product suppleness, and controlled quality of your standard of sweetness. I suspect that some batches may need variations in sweetening, or flavoring to put out a consistant-tasting product, but, as Kipling used to write - "That's another story".
Re: Solar Dryers
10/19/2011 7:42 AM
Dear vegan
i can give you best design for solar dryer.
please contact me
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 114
Re: Solar Dryers
10/19/2011 9:40 AM
it might be helpful if the moderation message said "Private Messaging system"
instead of "Internal Messaging system"
a link to the inbox too
http://cr4.globalspec.com/user/mail
the generic link goes to your mailbox, as long as you're signed in
Register to Reply 15 comments
Garthh (5); Gary Viveiros (2); Noudge79 (1); redfred (2); russ123 (3); santoshshivale (1); xanasax (1)
